My Ps2 will play some game, and others it won't, and when I try to
watch dvd's it only brings up disk read error! Why is this, I
want to watch my movies on the big screen instead of the computer;
PLEASE HELP ME.
If your PS2 is under warranty, take it back and get a new one. If not, you can try and fix it yourself. There's a few people that have written online guides for fixing this problem. Here's one example: Fixing the Disk Read Error. NOTE: If you open your PS2, your warranty will be voided, so beware! You could also damage your device if you do something wrong.
my ps2 wont recognize any disks. at first it read cannot read disk now it doesn't say anything it just goes right to the browser. when I reset it, it doesn't sound like the disk is spinning at all. Anybody know what this could be?
TB said: My PS2 just recently will not play a disc. It makes this noise like a vibration stuck noise and will not load any suggestions
Over time, things like lint and hair become trapped inside the disc-reader housing of your PS2. I had the same problem with mine, but it was easily fixed. If you don't mind voiding your service warranty, there's a way to save yourself some repair. Take the cover off your PS2 (the screws are under the little covers on the bottom of the console). With the screws out, CAREFULLY lift off the cover from front to back, and be careful not to pull on the foil power strip that runs to the on/off switch. Now remove the tiny screws that hold the cover onto the disc reader. Lift it straight up to remove it. With the cover off, you should see the familiar reader/laser assembly. Look for dust bunnies, entangled hairs, and anything else that doesn't belong. Remove them with a soft paintbrush, tweezers, or a can of compressed air. Do not touch the reader eye or laser assembly with your hands. When you're done, put everything back together. This SHOULD fix it, but if it doesn't, the problem may be with the spindle (the part that turns the disc). That part can be replaced rather easily at less than the cost of a new system.
my ps2 keep saying no data when i put in my cd and vidios do you think it is the laser.
my playstation2 wont turn on and i have all the wires plugged in all the way
PLEASE HELP ME
