Philips Magnavox- Smart series
5 posts / 0 new
amablecruz
amablecruz's picture
My Philips Magnavox-Smart Series. 14". Wont turn on. When I try to turn it on. Sometimes after hundreds of intents it would turn on, but after an hour or two it would turn off again. What can I do to fix this?
biggreeneyedgirl
biggreeneyedgirl's picture
amablecruz said:My Philips
biggreeneyedgirl
MINE IS DOING THE SAME THING
MINE IS DOING THE SAME THING ONLY IT JUST SQUEEKS<LIKE A BIRD CHIRPING ????
tv noob
tv noob's picture
I have a philips 27 inch tv
I have a philips 27 inch tv that has no picture or sound. When I plug it in, I hear a rapid beeping/ bird chirping sound. It seems to be coming from the largest part on the circuit board, a yellow cylinder with copper wire around it. The sound slows down and stops when I unplug the tv. The serial number is 27PT543S37A. Can I fix this?
tv noob
tv noob's picture
I posted this same problem on
I posted this same problem on Fixya.com and got this reply.
The "singing" you hear is an overloaded power supply and that could be a shorted horizontal output transistor as well as a bad flyback transformer. It's a possibility that you could even have an open B+ capacitor off the flyback transformer that supplies a voltage to the scan drives but most likely the earlier.
