JVC television picture is enlarged
11 posts / 0 new
JL
JL's picture
I have a fairly new JVC 32" I'art TV. When I turn it on now the picture is enlarged. It looks like it's at 125%. Is there a service setting to reset the size. There is nothing in the menu keys to resize the picture. I did try the obvious.(unplugging,menu keys,disconnecting everything attached).
Any help would be greatly appreciated.
Matt Whitlock's picture
If it's a digital TV, it
If it's a digital TV, it probably has a few different format modes to expand analog or widescreen movies to fit the screen. Look for a button labled "Aspect" or "Format" on your remote control.
Ed
Ed's picture
Thanks for the reply Matt
Thanks for the reply Matt this is not a digital TV. It does have a digital comb filter, but there is no Aspect or Format buttons on the remote. Any other Ideas? thanks
Hmmm.... Can you provide the
Hmmm.... Can you provide the model number? If the manual is available I can see if anything stands out.
Ed
Ed's picture
Hey Matt, The model number is
Hey Matt, The model number is AV-32WF35.
Techrat
Techrat's picture
Sounds like either the
Sounds like either the onboard memory has been corrupted or the high-voltage/horizontal circuit is failing. All the adjustments for this set, other than those in the customer menu are software controlled and 'tweeked' using either a link to a PC or a special hidden service menu. Take your set to a service center, preferably JVC authorized (so that they have the correct interface/data).
Techrat
Techrat's picture
If Matt can get the service
If Matt can get the service literature, you might be able to acess the service menu youself and make the adjustments, but 125% is a little high for a software error.
Ed
Ed's picture
Thank you for that info. I
Thank you for that info. I guess I will have to bring it somewhere unless I can get those service menus. I would be willing to try changing those if anyone has them.
Ed
Ed's picture
Is there a link anywhere to
Is there a link anywhere to get these service modes?
tt
tt's picture
Hi there,I have the same TV
Hi there,
I have the same TV set. I have just found out that My set was 1 year old this past November.
Same problem!! The picture is too wide! Not real distorted, just wide enough that I can't make out things on either side.
Is there a link for service modes??
I appreciate any help.
Ed
Ed's picture
tt,I ended up being under
tt,
I ended up being under warrenty on this problem. They came to the house and replaced a capaictor. I was not home so I did not see where it went, but the part # is QFP32GT-183 or QFF32GT-183. Hard to read, but I think it's the first one. hope this helps. It also has a ref.#514 not sure what this is.
