VChip HELP!!!
45 posts / 0 new
closetblonde
closetblonde's picture
VChip HELP!!!
My husband and I recently decided to join the world and get cable. We have two TV's with VChips in them, but I've lost the mauals and I can't find the codes online!! Somebody please help me!!
We have:
Philips/Magnavox MT2501C121
Symphonic WF203
Please help me!
Matt Whitlock's picture
closetblonde,The V-chip
closetblonde,
The V-chip access code override for your Magnavox TV is 0,7,1,1. You can download a copy of your Magnavox manual here.
As far as your Symphonic goes, I don't believe there is any pass code to the TV. If the words "Protected Program" appear, change to an unblocked channel and press menu. Go to V-Chip setup and change everything to VIEW in both TV and MPAA ratings screens. This should disable everything. You can download a copy of your Symphonic manual here.
Don't forget to tell everyone you know how much you love TechLore!
bruce king
bruce king's picture
need vchip  acess code for
need vchip  acess code for mitsubishi model # ws55809, serial# 105278
Larry Dillon's picture
Bypassing the V-Chip Lock on
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass.  This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip:  You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your  passcode is requested.  This process  temporarily unlocks the TV.
To reset the code:  When you use the button combination 9 and QV while entering the V-Chip Lock menu,  this process deletes your old passcode  and prompts you to enter a new passcode.
Good luck, and let us know how you made out with this TV set.
bobh
bobh's picture
i have a esa tv and lost the
i have a esa tv and lost the remote and manual;all of my v-chip channels are blocked how can i clear it or reset it please help me.
Well, first off, I have never
Well, first off, I have never heard of that brand. Second, If I could find it, you would most likely need an original remote unit. Maybe go back where it was purchaced and see if any of the sles peeps knows anything about it. GOOD LUCK!
matt33
matt33's picture
got a used sharp t.v dont
got a used sharp t.v dont know the v chip code the dog ate the remote can u help resetting the v chip have a universal remote
nope, I am sorry you ned an
nope, I am sorry you ned an original mote. a univeral wil not work.
DRR
DRR's picture
I have a panasonic tv set and
I have a panasonic tv set and I never got the manual when I got the set can anyone help me to unlock it? I do have the original remote if that helps.
Panasonic sets need to be
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
Steve1
Steve1's picture
I have a Protron tv, model:
I have a Protron tv, model: PLTV-4250, I'm looking for the manufacturer vhip codes for the tv. Thank You
et.
et.'s picture
I have sharp tv model- 20f640
I have sharp tv model- 20f640 forgot v chip pin code, is any body out there can help me how to reset it or remove it? thanx
Dan250
Dan250's picture
hi everyone i need help
hi everyone i need help unlocking my sharp 27" tv Can someone help Thanks
et.
et.'s picture
Dan250
Dan250's picture
Carman
Carman's picture
I have a mitsubishi and the 9
I have a mitsubishi and the 9 QV worked, but how do I get the V-Chip Lock to reset the passcode, or better yet, turn it off completely?
Thanks so much for your help!
Babydoll3133
Babydoll3133's picture
Hello all. I have an Emerson
Hello all. I have an Emerson "Spongebob" set. Even with the original remote, I can't get the vchip to work. Please help.
chicquita
chicquita's picture
Hello I have a mistubishi HD
Hello I have a mistubishi HD 1080 i purchased it used and don't have the orignal remote and reacently discovered that the v chip code was need to view all channels and I don't have the past word to remove it can you help me please it's model number is ws-55315 and i have universal remote by phillips pleas help
you cannot reset the V-chip
you cannot reset the V-chip with a universal remote, only with an originsl type remote.
Hey gay12345890=xd, whats
Hey gay12345890=xd, whats with the rude commmit? We are only trying to help you. If you do not like the snswer please ask somewhere else.You should be band from asking any othr questions but maybe you were having a bad day?
Roy cope
Roy cope's picture
I have a Mitsubishi tv and I
I have a Mitsubishi tv and I lost the remote and the manual for the tv. I would like to know how to override the V-Chip lock on my tv?
Nope I'm sorry to say you
Nope I'm sorry to say you will need to borrow or get an original remote control to clear out the V-chip code.
Donna
Donna's picture
i have a panasonic but dont
i have a panasonic but dont have the regular remote i have a digital dvr remote will i be able to reset with this remote?
No sorry you will NOT!, as
No sorry you will NOT!, as you need an original remote control See if a friend, relative or a neighbor has one you can borrow.
Billy joe
Billy joe's picture
i have a ilo 42 inch some how
i have a ilo 42 inch some how my nephew has added a code to lock out pg 13 shows how can i unlock or reset v chip?
UncleDoug
UncleDoug's picture
Hope this will be easy.
We have a Protron PLTV 3757 that was return item. No one know the pass code to unblock the TV channels one is the local PBS station and the other is an independent station.
Thank You for your Help !
The Original reason this unit was returned is a large dark smudged area 3 by 5 near the top center of the screen.
you will need to contact
you will need to contact proton on this one!!! GOOD LUCK!!!!
UncleDoug
UncleDoug's picture
Larry Dillon said: you will
Larry Dillon said: you will need to contact proton on this one!!! GOOD LUCK!!!!
Unfortunately I cannot find a Protron website that might have a support link.
 I know there is another name now and wondered if you might have an url for either so I can contact them.
Thank You again
UncleDoug
Ronnie3144
Ronnie3144's picture
I have an Emerson tv with the
I have an Emerson tv with the original remote but cannot access the ratings changes due to it asking for my acces or pass code. What do I do? I have no manual or codes of any kind!
Nollins
Nollins's picture
I need help with WS 55315 v
I need help with WS 55315 v chip lock I dont have a remote
I am sorry but without the
I am sorry but without the original remote there uis nothing me nor I can do to the set as it takes the original remote to unlock it. maybe a local store or a neighbor, a friend could help you outby loaning you a remote???????
Larry Dillon.
