Using Sony PVM-4300 45" Monitor-----HELP!!!!!!
wderekblaine
I admit that I am computer illiterate and need help figuring out how to connect a tuner and a computer to this massive monitor. I have been told that I need tv card for the computer (Compaq 6000)but I don't know what kind.
I have a Sony STR_D990 receiver.
Any help would be appreciated or any push in the right direction...........thanks
Matt Whitlock (not verified)
Cool project. This is the
Cool project. This is the kind of stuff I love to do. Can I make (blank) work with (blank)? How fun! Here's some info that may help you.
First, I need to know What you mean by a "tuner"? Are you referring to the Sony Receiver?
To make the connection between your computer and your set, you'll need to purchase a 15-pin VGA to 5-wire RGB cable. You can usually get them at a local A/V shop or online. I recommend the Straight Wire brand of cables if you can find a dealer in your area.
You'll want to connect the TV to the 5-wire RGB input near the bottom of the jack pack, which is compatible with a 31.5KHz signal. This roughly translates into 640x480 at 60Hz on your computer, though you may be able to set it at 720x480.
You do not need a TV card for the computer unless you wish to use your computer as a TV tuner, or to record TV programs onto the computer hard drive.
Good Luck. Post back with updates as to your progress.
