1105 posts / 0 new
sheriisfun
sheriisfun's picture
Larry I too had the blinking
Larry I too had the blinking green lights, but it has always fixed itself, untill 3 days ago, No more blinking green light and no power. Can you send me the file you mentioned? sheriisfun@cox.net thank you
65" HDTV Mitshibushi Diamond WS65711.
sheriisfun
Also any links to parts
Also any links to parts supplies would be great too.
John R
John R's picture
Hi Larry, I hope you are
Hi Larry, I hope you are still around
I've got a mitsubishi with the same ominous green light issue! Can you send me the file you mentioned? I have a Mitsubishi WS-55909
Counterbalance
Counterbalance's picture
I have the same blinking
I have the same blinking light problem with a Mitsu ws-65711. Could you email me the fix to jbenson8989@yahoo.com?
BigMac99
BigMac99's picture
I have an Mitsubishi LT-40151
I have an Mitsubishi LT-40151 that when powered on has blue screen and the power light flashes for 15 or so seconds then tv powers off, any ideas?
Melissa726
Melissa726's picture
Have the same blinking green
Have the same blinking green light problem. I don't know anything about tv's. please help!!!
Melissa726
I to have a blinking light
I to have a blinking light problem and are pretty handy with fixing things i have a Mitsubishi ws-65712 and need to know to fix .can you please email me anything you have thx kgservices04@yahoo.com
soccerfranc
soccerfranc's picture
Hi Larry - We have a ws-65711
Hi Larry - We have a ws-65711 - we had a power surge or interruption for a millisecond - The TV was off and when I turned it on it indicated a power loss. Ater turning the set off and then on again, the green light lit and then went off after 3-5 seconds. It does not keep blinking. Tried resetting and disconnecting the power over night. Are the capacitors on the DM board the likely culprit? If you think they are, please send the file on how to repair. Hoping to eek out a couple of more years now that I've hooked up a hdmi to componet adapter which works great. Thanks, soccerfranc
rick3014
rick3014's picture
I have the same green
I have the same green blinking light after a power outage. Could you please send me the same file? Thanks
Berny
Berny's picture
Can you please send me the
Can you please send me the fix for blinking lights. Thanks
Bernzik@yahoo.com
azvampyre
azvampyre's picture
I have a wd-y577 with the
I have a wd-y577 with the flashing timer light. After 60 seconds something clicks and I can hit the power button but the light still blinks. The bulb glows and the color wheel spins, and there's a faint light on the screen, but its barely noticeable. If I hit reset, the screen flicker a very faint light and does it all over again.
This unit uses the V37L chassis, and tvrepairworld doesn't even offer kits for this one.
Could this still be the caps on one of the boards?
I replaced the bulb, but no difference. There's also no sound.
Heath123
Heath123's picture
Mitsubishi Model WS-65711
Mitsubishi Model WS-65711 would not shut off so we unplugged it. Now it will not turn back on. We get green flashing light for 60 seconds and then still unable to power back on. Any suggestions? thanks,
HPennel
HPennel's picture
I have a WD-65733 with the blinking green timer light and won't turn on. Could you please email those procedures and pics to me as well? Thanks!
evil
evil's picture
LARRY is no longer with us
rick3014
rick3014's picture
I found the pictures on the
I found the pictures on the internet. You have to get into the metal box that is closest to the left wall of teh tv and you will see the 7 fuses on a card. I am not sure where I found them but this seems to be a common problem with these tvs. I ordered 7 fuses off amazon took the whole tv apart and soddered the fuses to the card and low and behold the tv worked again. I have never done anything like this before so I was very proud of my self.I ordered the Rubycon 1000uF 35V Thru-Hole Aluminum Electrolytic Capacitor Low Impedance 20% (Bag of 10) but I could have ordered the 25 v instead. If I had to do it over again I would order the 25 v because the 35v were too big to get a good fit but they worked and the tv has been running fine for 3 months. My tv went out on a power surge and the green blinking light was on the power button.
smiff24
smiff24's picture
I have a WS65711 with a
I have a WS65711 with a blinking green light too, I would appreciate if you could send me the document to smiff24@hotmail.com. Is there a way to degauss these models?
evil
evil's picture
Isnt that a dlp? Why on earth
Isnt that a dlp? Why on earth would you need to?
harold e
harold e's picture
Larry please send to me model
Larry please send to me model ws55511 s
ame problem light flashing
Mitsubishi WS 65711
Mitsubishi WS 65711's picture
Larry: I have the blinking
Larry: I have the blinking green light. Please e-mail your package.
THX IN Advance. :) Dave Fay
evil
evil's picture
It can be found in the
It can be found in the service manual section.
Sandy Double
Sandy Double's picture
I also have the green light
I also have the green light problem Model WS65711. A couple of days ago our TV went up full blast and we could not get it to turn down unless we got up and used the Volume down button in front of the TV, as soon as we released the button it went right back up. Unpluged TV and now that we have turned it back on we have the green light and TV will not work HELP
krayzie993
krayzie993's picture
Larry ive the green light as
Larry ive the green light as everyone else model ws-73909 would appreciate you sending me the information to make the repairs,thanks
evil
evil's picture
Click the link below and find
Click the link below and find the repair kit for your model tv. It will have instructions as to what to do.
Wd-65733
Wd-65733's picture
My will turn on but no
My will turn on but no picture. I tried unplugging it several times and waiting but still nothing. The green light will blink 6 times and they say its a lamp issue. But also to the right of the lamp is a spark that when the tv is turned on it will spark a few times and stop and will do this about three times then the tv shuts off. Any clue?
evil
evil's picture
That spark is the ballast
That spark is the ballast trying to fire the lamp. If you are getting spark then you need to replace the lamp.
1GooDPat
1GooDPat's picture
Larry, I would also
Larry, I would also appreciate any help with my 'blinking green light'. I have a Mitsubishi WS-65711. goodmanp48@gmail.com
WenMos
WenMos's picture
Hello. I have the same
Hello. I have the same problems with my WS-65711: power in house went out for brief minute, tried to turn on TV n it wld not turn on due to constant green blinking light. Reset nor power unplugged did not work. Please email the repair with pics to wamosley@verizon.net. Thank you.
Djqballyall
Djqballyall's picture
Hello all, i hope someone can
Hello all, i hope someone can help. I have a wd-62725. I turn the tv on, the power light comes on and stays steady but nothing else comes on( minus the power supply fan). No light no ballast clicking no other fan ,nothing. I replaced the power board and check caps and still the same problem. Thanks in advance for any help that may come my way.
Aimee Shaw
Aimee Shaw's picture
Larry - can you send me the
Larry - can you send me the details for the flashing light fix?
We have a Mitsubishi Model WD737333
dsandri
dsandri's picture
Larry - I seem to have the
Larry - I seem to have the same problem. I have a Mitsubishi Diamond Series HDTV 1080 model no ws65711 with the blinking green light. I've got nothing to lose by trying the repair - if you are still sending that info out.
thanks in advance.
Dean
