Sony 42" KE-MX42S1 Turns itself off.
6 posts / 0 new
lifestylewood
Can anyone shed some light on my dilemma?
When I turn the T.V. on it will go for a few seconds and then turn off, it has a red light that flashes 9 times over and over.
I have found on this site that it means I would most likely need to replace capacitors (D6116 and D603) located on circuit board 'G'
I have taken the back off and looked around but can not locate the circuit board 'G'.
Does anyone know where to find this circuit board and the 2 capacitors?
Also could it be something else that is the problem?
evil
I'm not shure if you have a G
I'm not shure if you have a G board,your tv is a plasma right?the components you described were diodes not capacitors?
bustr
Yes it is a Plasma, I am not
Yes it is a Plasma, I am not a whiz when it comes to electronics, but I am going to have a go at fixing this tv myself.
Do you know this model at all?
What is wrong with it if the red standby light flashes 9 times? and how do I fix it?
evil
I just read through the
I just read through the service manual but it didn't have trouble codes in it,sorry not shure what the 9 blinks means. I'll upload the manual to techlore tomorrow.
evil
The diodes you referenced
The diodes you referenced earlier arent in the parts list in the Manual for your model so that must have been a different set that you found a repair for. Here is the manual for yours maybe some of the voltage charts and shematic diagrams will help you.
http://www.techlore.com/download/37299/Sony-Chassis-AX-1-Plasma-Service-...
bustr
It might have been for
It might have been for another model? I just googled it and that was what I found.
Thanks for the manual, I will have a read through it tonight and see if there is anything usefull in there. Thanks
