Can anyone shed some light on my dilemma?
When I turn the T.V. on it will go for a few seconds and then turn off, it has a red light that flashes 9 times over and over.
I have found on this site that it means I would most likely need to replace capacitors (D6116 and D603) located on circuit board 'G'
I have taken the back off and looked around but can not locate the circuit board 'G'.
Does anyone know where to find this circuit board and the 2 capacitors?
Also could it be something else that is the problem?
I'm not shure if you have a G board,your tv is a plasma right?the components you described were diodes not capacitors?
Yes it is a Plasma, I am not a whiz when it comes to electronics, but I am going to have a go at fixing this tv myself.
Do you know this model at all?
What is wrong with it if the red standby light flashes 9 times? and how do I fix it?
I just read through the service manual but it didn't have trouble codes in it,sorry not shure what the 9 blinks means. I'll upload the manual to techlore tomorrow.
The diodes you referenced earlier arent in the parts list in the Manual for your model so that must have been a different set that you found a repair for. Here is the manual for yours maybe some of the voltage charts and shematic diagrams will help you.
http://www.techlore.com/download/37299/Sony-Chassis-AX-1-Plasma-Service-...
It might have been for another model? I just googled it and that was what I found.
Thanks for the manual, I will have a read through it tonight and see if there is anything usefull in there. Thanks
