mitsubishi wd- 52725 has continuous blinking light
tvjon
I would really appreciate it if any one has the manual/guide on what bad capacitors to replace on the boards and what capacitors to use to replace them with. My email: [email protected] Thanks
claudio
If you replace the caps in
If you replace the caps in the DM broad and on the FMT broad also the power supply. some times this will work, but sometimes i doesn't work. Mitsubishi has a recall on the TVs. You have to call a Mitsubishi service center to get repair. What they do is send the chassis to Mitsubishi for an overhaul and then send it back to you. this could take about 3 to 4 weeks. Mitsubishi will cover the cost to repair the chassis you will have to cover the labor from the shop. If the TV fails after repaired you usually get a new TV.
