I would really appreciate it if any one has the manual/guide on what bad capacitors to replace on the boards and what capacitors to use to replace them with. My email: [email protected] Thanks
Copyright © 2020
If you replace the caps in the DM broad and on the FMT broad also the power supply. some times this will work, but sometimes i doesn't work. Mitsubishi has a recall on the TVs. You have to call a Mitsubishi service center to get repair. What they do is send the chassis to Mitsubishi for an overhaul and then send it back to you. this could take about 3 to 4 weeks. Mitsubishi will cover the cost to repair the chassis you will have to cover the labor from the shop. If the TV fails after repaired you usually get a new TV.
