SONY HDTV Projection TV Convergence Problem
BillNew
I have a SONY 57" HDTV projection TV that is only about 4 years old.  I can't find the model number as it is on the back of the unit and it takes two men and a small boy to move it.  I read your article on the SONY Convergence problems & solutions and wonder if this info is current enough for the HD projection models.  I don't know if SAMS service manuals are available anymore.  I used to do a lot of hands on TV service including about 100 CRT monitors at NBC master control in Chicagto.  But, that was over 30 years ago and technology has moved on.  So I would appreciate any suggestions.  I  might add that the speaker grill on the front is removable, which allows access into the electronics area.  Thanks.  Bill
slinteriors
most all of the HDTV sonys
most all of the HDTV sonys use two STK392-560 convergence Ics located on the D board also on the d board are 6 3.5 amp pico fuses which will usually burn out when the ICs go. You can get replacement ICs and the pico fuses at the following link and they provide free instructions.
http://servicemanuals.vstore.ca/
