Concave picture on my RCA projection tv...
6 posts / 0 new
Candy013079
I have a 1997 RCA projection tv that was given to me about two weeks ago, and it has been fine until this morning...  it now has a concave picture...there is a space at the top and bottom of the picture...  is there a way for us to fix it ourselves, if not, who do we call and how much will it cost?
Silva
If you don't know what a
If you don't know what a chassi # or modle# is!  take it to a tech.
Candy013079
Actually I do knkow the model
Actually I do knkow the model# and the chassi#:  M# is P52835LV
C# is PTK195BB
Candy13079, your set sounds
Candy13079, your set sounds like you have a horizontal correction circuit problem  or a convergence problem.. Does the picture look 3-D  are there color lines on the outline of the images on the screen?
Candy013079
Yes, there are color lines
Yes, there are color lines that 3d all of the words and pictures on the tv.
Ok you have the typical
Ok you have the typical convergence problem. These RCA circuits are a lot differant then the sets with convergence ICs. you will need to get a service manual and trace out the drive circuits. If you have no solid state repair experience, play it safe and call in a pro to assist you with this repair. Good Luck and let us know what it took to repair your TV set.
