removing scraches from big screen protective shield
4 posts / 0 new
trav
how do i remove scratches from a protective screen on a big screen tv
Sorry, but really the only
Sorry, but really the only way is to replace the screen, unless you have the plastic buffer equipment. I never seen this, but have been told, those disc repair systems that you apply a little compound and use a hand held buffer has worked for a few, as long as the scratches are only small surface scratches.
wsm
try high grade car wax  just
try high grade car wax  just be sure the buffing compound in the brand of wax is very fine  you can feel it with your fingers
dbase11
For external Diamond Shield:
For external Diamond Shield: Use a foam car wax applicator and Mequiar's PlastX, clear plastic cleaner and polish (incredible for plastic headlight lens scratch and haze removal as well). I do not believe one can remove scratches from the internal screen.
I have a Mitsubishi, 2002 model 65" projection TV with diamond shield. My Diamond Shield had a 6 in long scratch from a board falling across it (not minor surface and not too deep). It also had minor surface scratches from kid's play. I was able to completely buff out the larger scratch and proceeded to buff the entire diamond shield to remove the rest.
What I did: Wet foam applicator, apply a half inch drop of polish (more if a larger scratch) and buff over the scratches in a circular motion using firm pressure initially, reducing pressure as you go and finish up with light pressure until the scratch is completely buffed out.
After buffing I used a wet microfiber towel to clean/remove polish residue and followed up with a dry microfiber towel to remove water spots.
Entire process took around 30 minutes.
