Green Shadows - Sony KP-53V80
3 posts / 0 new
Hefitz
Getting some green shadows at the edges of bright white images.
In other words, when an when a bright white image, such as say sunshine coming through a window (image on screen. not window in my house) there will be a green shadow along the edge of the white.
Any ideas? Hope I explained this properly.
jreth
Did you get an answer to this
Did you get an answer to this?  I have the exact same tv and problem.
dans_repair_service
You can try replacing the
You can try replacing the following components.  When these fail or begin to fail, the pix will get bright and may cause convergence problems +/or shutdown.  Replace SG702,SG732,SG762 (spark gaps) Sony part number 1-517-729-31 ($5.81 ea).  Replace Q706, Q733, Q764 (transistors) Sony part number 8-729-200-17 ($4.47 ea).
Dan
