Getting some green shadows at the edges of bright white images.
In other words, when an when a bright white image, such as say sunshine coming through a window (image on screen. not window in my house) there will be a green shadow along the edge of the white.
Any ideas? Hope I explained this properly.
Did you get an answer to this? I have the exact same tv and problem.
You can try replacing the following components. When these fail or begin to fail, the pix will get bright and may cause convergence problems +/or shutdown. Replace SG702,SG732,SG762 (spark gaps) Sony part number 1-517-729-31 ($5.81 ea). Replace Q706, Q733, Q764 (transistors) Sony part number 8-729-200-17 ($4.47 ea).
Dan
