tv will not come on ?
4 posts / 0 new
buckie
A friend at work as a panasonic tv when you plug it up  the relay starts clicking you dont have to hit the power butten just plug it in .
kosmicblue
try unplugging it for 30
try unplugging it for 30 seconds or so , then try again
dans_repair_service
Please provide the model
Please provide the model number so we can help.  Thx. Dan
The model number as Dan
The model number as Dan requested is good to have, but some Panasonic's do go through a start up stage when you turn them on.  The power relay will click and then the set will go to a stanby state.  When the relay clicks on and off, do you feel or hear the high voltage static on the screen.  If not, there is a short in the sweep circuit somewhere, if you do, check all the capacitors in the standby power supply circuit.  Good Luck
