Sony TV KV 32FQ75 - POOR Infra red range
DLB
THE RANGE HAS JUST DROPPED TO WHERE ANY REMOTE WILL ONLY WORK NEXT TO THE SENSOR.
ANY ASSISTANCE WOULD BE APPRECIATED
DLB
The IR sensor is probably bad
The IR sensor is probably bad, or there is a 5 volt regulator that supplys the voltage to the IR sensor in the standby power supply that I have seen cause this problem.  If you have no training in repairing TV set, I would advise you to call in a pro, as the IR sensor is all the way in front of the TV set, and you will need to pull out the entire chassis to repair this problem if that is the fault.  Good Luck, and let us know how you made out.
