Hey all.
Last night I was watching television and fell asleep, leaving it on all night. When I woke up, the television was still on, but everything was black except for this thin, 1cm thick, horizontal line in the middle. I still had sound, and when I tried to change channels the colors of the line would change, as if the channel was coming through that thin line.
I've turned the power off and on, unplugged everything from it, flipped through all the channels, but it's the same. Also, whenever I changed the channel I'd see a part of the channel number display on the line, which is weird since normally it's up in the rightside corner, not near the middle.
Any help or advice would be appreciated. Thanks.
Symphonic 20" Flat Screen TV strange line problem
Thu, 06/23/2005 - 13:09
#1
Hello MattP, welcome to the TechLore Community!
I've read your problem, and it doesn't look good. You didn't mention that you unplugged the TV from the wall. Try unplugging the TV for about 4 hours. When done, plug it back in, cross your fingers, and turn it on. Let us know what happens.
hit tv if fills out resolder pins on vertical ic if not replace vertical ic
My onida 21oxygen tv colour is not right he colour is red red who right this problem plz help me.
