Did the convergence repair about 3 years ago, and the TV has been great since then until the following happened last week. Turned the set on and heard a high pitched whine from inside, no audio, and a distorted picture for about 15 seconds. Then everything worked normally. The next time we turned the set on, we get a Timer/Standby light fault code that looks like it flashes 3 or 4 times once, then 6 times over and over. When I press the power button now, I do hear the high voltage kick in for a second, then the relay cuts the power. I've uploaded the fault code video here:
I have the service manual, but don't really understand the sequence of fault codes that I'm seeing. Any suggestions as to how to proceed? Thanks in advance.
Everett
