HY,everybody!Someone knows this '80'camera? I would try to connect to a VCR, but I could use the 8-pin'pattern of the socket on the handle to try to make my cable (I would try to connect or via scart-socket, or antenna ), but I have to feed it (6.5 W at 12V). Can anyone help me?I need the correct 8'pin connection's diagram.. Thanks!
OOpps,thats GoogleTranslate,excuse-me,I would like to try to re-explain:to connect the camera at the vcr (and give power to the camera) must use the 8-pin socket located on the handle, I need the right diagram of this socket (circular, 12 mm in diameter, reminiscent of the old "GELOSO"'s jacks , 6 pins arranged in a circle, and a seventh pin exactly in the middle). Does anyone know the pattern so I could make a cable? Thanks, and sorry for my non-English, and use GT is usually worse.
