I have a 3 year-old RCA TV (L26WD23). I press the power on button. The green light comes on, then the amber light blinks several times and the TV goes off. I go through this process 10-12 times. Then the TV stays on long enough to see this message: "The time stoared in the TV may be incorrect due to a power failure. Set the time using the Options menu." I have set the time repeatedly. (Some times it is already correct - sometime not.) The next time I turn on the TV, I have to repeat this process. I have turned the TV off and let it sit for 5 minutes as recommended in the Guide. Any other ideas?
RCA TV goes off when turned on
Tue, 10/25/2011 - 10:01
