My WS55813 had a problem resetting the picture and volumne repeatedly. So I shut it off, unpluggedit, took off the back and vaccumned it out hoping it was heat build up from poor maintenance. Put it back together, plugged it in tv didn't turn on frompanel or remote, pushed the rest green light blinked as usual and was able to turn on tv but still reset picture and volumne, turned it off now tv wont turn back on but the light still blinks when you push the reset. What might be the issue?
How many times is it blinking when you try to turn it on? Or try holding menu and device for 5 seconds and count the flashes.
If the power indicator blinks non stop green then its usually related to the DM capacitors not charging so the DM can complete its boot sequence and the led will blink non stop.
