Another Phillips 60pp9202 red convergence problem
sdom001
Hello guys, I've read the other threads and have followed the suggestions and i am still having a problem so here's my story.
I first replaced the stk392-120 ic's with 180's. I ordered the 150's but due to a shipping screw up the online store replaced them with 180's and said that thats what they used when fixing the same problem. Anyway i replaced them and nothing. then after further research I found out about the possible burned out 6.8 ohm resistors and found 2 so replaced those. turned on tv and still same problem. I then went to look and the 2 i just replaced were burned out again.
I did further research and found out I needed to replace all 12 resistors. I did and after turning on the tv and still finding the same problem with the red convergence i went and looked and the 2 same resistors were burned out again.
I can move the red convergence up and down but it won't move left or right and thats what I need to align. Please help
evil
I see 5 red horizontal
I see 5 red horizontal resistors and 2 capacitors.Check resistors 3092,3162,3153,3154,3095.3153,3154 are on the same circuit and are both the same value 6.8 ohm so one may be bad but you may still get a reading of 6.8 from the other good one unless you remove one of the legs of the resistors and test them or use a diode function on your DMM-digital multi meter.The capacitors(2109,2060) you cant really test without the proper equipment so it probably wouldnt hurt to replace them.Even then you may have already damaged the sensitive semiconductor inside the IC.It probably wouldnt hurt to get some voltage readings.
