I have a Mitsubishi WS-55511 model that turns on, then turns off within 2-3 seconds. I have read alot of post's on the net about this problem, but I dont know how to check certain componets that I need to. I have the v21 service manual for it, but it does not tell you how to diag. I do have an error code of #23. I have checked every fuse and all are good. I have already replaced the capacitors in the DM but no help. I did get the TV to work for about a month by turning down the gain dials, then it would power on and stay on, then I had to adust the color, sharpness, etc with the gain dials. If I turned the gain dials up too much, it would turn the TV off. Now its not turning on even when I have the gain dials all the way down, system reset worked once or twice, but now if does not help at all. Like I said, every fuse listed is good. I need some help to diag what componet is at fault. I am an auto tech and have hands on, I can solder, and I have time and patinence to do it. Please help
JUST PUT TODAY SOME PARTS FOR SALE IN EBAY FOR THIS MODEL LOOK UNDER ELECTRONICMODULES OR VENTAS INTERNACIONALES
That would help if I knew what I need!! Your just trying to sell parts, good luck
http://www.techlore.com/forum/thread/25127/Mitsubishi-v21-WS-B55-Error-c...
Try what slinteriors suggest. I hope you marked the g2 and screen potentiometers original position,you shouldnt mess with those you can do alot of damage to the set.
