I have a Mistubishi WD-62525, I recieved the yellow blinking light for the lamp and have since replaced the lamp but the image still does not show on the screen. It sounds like the television turns on, the fans and the sound is working fine but there is no image. What else should I do in order to get the image back?
Could be the lamp ballast,or did you change that with the bulb?How many times it blinks could be an indication of whats wrong with it check in the Service Manual section of this site for the Service Manual for that information.
I did not change that with the bulb but Ill check the ballast. The light isnt blinking, its the yellow lamp light the stays solid as long as the television is plugged in. I do not have th service manual, do you know where I might be able to purchase a service manual?
