sony kf42sx300u led flashs
daphney
hi i am new here & 1st i like to say that im very impressed with the info i have found alreadySmile
i have read this post kp-46wt520 9 blinks  from start to finish & found very interesting
as my tv have a similar fault.  so i have pulled out power supply board from tv & says g under sony   so guess it gboardEmbarassed
but all diodes i see start with d1   & cant find d6301 or d6116   anywhere
so as its a different model can some1 tell me if i got correct board out & what diodes i need to check if are different numbers  thnx
ps board was 1 closest to mains power lead
thnx in advance
evil
You cant apply fault codes
You cant apply fault codes from what you have found for another model muchless for a different chassis to the set you have.9 blinks for your set is the tuner.
evil
Is your chassis number for
Is your chassis number for that set LE-4A? If it is i can upload the manual for you.
