I was given a dell dimension 1100 (deo51 series) with xp the hdd had gone and i had a windows xp hdd installed the windows xp and then you can here 2peeps when switched on (bios version A01)
When i switch it on you here2 beeps then on screen comes up Primary drive 0 not found Primary drive 1 not found Secondary drive 1 not found strike f1 to continue f2 to run set up utility when i press f1 it comes back to strike f1 f2 strike f2 and comes to setup utility move pointer to boot sequence and then comes up with tick 1 diskette drive tick 2 Ide cd-rom device tick 3 hard disk drive (not installed)
so could some one tell me what the problem is
eric vista
http://www.overclock.net/amd-cpus/120949-how-do-i-set-my-harddrive.html
