Tip of iTunes to DVD Burner - Burn iTunes DRM Protected M4V Videos to DVD
1 post / 0 new
LynnLU
When you purchased a video file from online stores like iTunes and Microsoft Media Center, you will get a DRM protected M4V or WMV video. You can watch it as many times as you want on your computer. If you want to burn iTunes video to DVD so that you can watch it on your TV, you will have to remove DRM protection and then you will be able to burn and convert DRM videos to DVD using DVD burning software. This tutorial shows you the step-by-step guide on how to remove DRM protection and Convert iTunes to DVD.
Part 1. How to Remove iTunes DRM Protection before Burning DRM Videos to DVD?
Fristly, you need a professional tool to remove iTunes video DRM Protection, DRM Media Converter is a perfect DRM remover which enables you to remove DRM protection from movies and music bought from iTunes, Microsoft Media Center, Napster, etc.
Step1. Import DRM video files
Locate DRM video files on your computer and add them into the program.
Step2. Customize output settings
Select an output format from "Audio files to" or "Video files to" drop down list.
Step3. Remove DRM protection
Click on "Start" button to start removing DRM protection once you've finished all settings.
Part 2. How to Burn iTunes DRM M4V Videos to DVD Format?
The simplest application for burning DVD from iTunes video is iTunes to DVD Burner. This iTunes to DVD Burner allows you to burn DRM removed M4V, WMV and many other videos to DVD which can be viewed on normal DVD players. Highly recommended!
Step1. Import iTunes DRM videos to the iTunes movie to DVD Converter
Launch iTunes to DVD Creator and click on Load Video button to add DRM removed videos to the program. Drag and drop imported videos to storyboard below to organize title set.
Step2. Edit iTunes DRM videos (Optional)
The plug-in video editor lets you edit videos by cropping, trimming, adding watermark, adjusting video effect, etc. You can also customize the DVD menus and transition effects to create the most personalized DVD project.
Step3. Burn iTunes DRM videos to DVD
Click on Burn tab and this iTunes to DVD Burner gives you 3 output options: burn iTunes movies to DVD disc, DVD Folder and ISO Image file. You may select DVD and simply click on Start button to burn iTunes videos to DVD.
Once you've finished the DRM videos to DVD conversion and burning, you can watch the DVD on your home DVD player with your family members and friends. Apart from burning M4V movies to DVD, this iTunes to DVD burner also lets you burn DVDs from many other kinds of videos for playing iTunes movies on DVD.
PS: For Mac users, if you have some iTunes videos without DRM, and you want to Converte or Burn iTunes to DVD on Mac OS X, you can finish your work get DVD movie from iTunes videos on Mac with iTunes to DVD Burner for Mac.
