Howdy from Arlington, Texas.
I live 17 miles from the closest broad cast tower. The Zenith TV upstairs cannot pick up and hold the signals for Channel 68.1 or Channel 68.2-it will pick and hold the signal for Chanel 68.3
Picture comes in and less than 30 seconds later, the screen turns white.
I have repositioned the smart antenna, turned the knob on the smart antenna, repositioned the antenna in the direction of the tower (provided by antenna web-based on zip code)
HELP!
Roseannethelibrarian
Normally with reception woes (particularly in the digital age) not adequately receiving a signal means you need a bigger antenna or need to move it higher. What kind of antenna are you currently using?
It's odd that it turns white. Do you have another set in the house to test with? If you plug that antenna into another digital TV, does it work?
