How to rip and Convert Blu-ray 3D to MKV 3D Video
Once you wanna convert Blu-ray 3D to MKV 3D video for playback on some display devices or player software, you can turn to DVDFab Blu-ray 3D Ripper. Next is a step by step direction on how to fulfill this conversion with this easy-to-use, professional and powerful tool.
Blu-ray 3D to MKV 3D > Step 1: Go to the right mode of Blu-ray 3D Ripper, then open source
After Blu-ray 3D Ripper is downloaded and installed, select "to MKV" mode. Then insert Blu-ray 3D disc, or click the file folder or image file icon beside "Source" to open source. And you will be asked to specify a region code of the Blu-ray, go ahead.
Blu-ray 3D to MKV 3D > Step 2: Choose preferred subtitles and audio tracks
After source Blu-ray 3D is opened, you need to choose subtitles and audio tracks for the title you want to convert, just choose your preferred ones.
Blu-ray 3D to MKV 3D > Step 3: Optional editing before converting
Set video and audio format:Click Edit button on the main interface, Conversion Settings window will be opened, and you are capable of setting video and audio format freely here, such as, bit rate, frame resolution, aspect ratio, frame size, channel, volume, etc. By the way, you can also split a title by chapter if you desire for smaller individual outputs.
Note:Click Open Queue button on the main interface, Mobile Task Queue window will be opened, at here you can remove a task or add a new task by coping an existing task then change its profile.
Set video effect:Click Video Effect Settings on the above interface, then you can edit the video effect at your whim. You can resize the source aspect ratio and frame resolution; you can crop video's play region manually or automatically; you can also choose the 3D type to be left/right, top/bottom, 100% or 50%.
Blu-ray 3D to MKV 3D > Step 4: Start converting
Hit Start on the main interface to start converting. You can follow the detailed information of the progress, view the pictures from the source Blu-ray changing with different stages, and use auto shutdown function to release yourself during the converting process.
That's all for the whole process of Blu-ray 3D to MKV 3D conversion. Do you feel the power and charm of DVDFab Blu-ray 3D Ripper now?
Tue, 02/01/2011 - 01:52
