Phillips factory code
4 posts / 0 new
montico
plillips tv is in factory code model 21pt9470/55 need to unlock con you help?
montico
factory code is the only
factory code is the only thing that comes on the screen written
evil
Sometimes you can hit channel
Sometimes you can hit channel down and volume down at the same time for 5 seconds you may need to set the G2 control on the flyback untill all retrace lines are out.That is if you meant Factory Mode instead of Factory Code
montico
we are on the island of
we are on the island of Curacao 60 miles from ArubaThe technitian is saing factory mode and when we power it up no other button will function
