I have a Samsung rear projection screen TV model HCL552W and the convergence will not line up
When this first happened, I bought a new convergence modual and it did not help fix the problem
Therefore, I bought new convergence chips and this did not help then I bought a new Power/Deflection
board and put it in And it is still not working the red crosshairs are tilted to the right is there anything anyone can Think of that might be the problem or does any one know were I can get a service manual or
Is there a way to reset the convergence to the factory settings any help would be greatly appreciated
I2xcelr8
Did you check the resistors/pico fuses around the convergence chips when you replaced them?On page 59 of the MANUAL it gives a troubleshooting guide for the convergence.
The board were the convergence chips go is brand New when the chips did not work I bought the whole board
I2xcelr8
Sounds expensive,are there any errors in the service menu?a picture would be great,there is a way to set the convergence to factory.
