tv wont power up checked it out and found this yellow fuse open 3.15 amps on power supply board. i think it might be the 2 stk 392-560 any help or comments welcome as this is my only tv and i would like to get it working soon.
i think the stk's are convergense IC's anymore info on what happend before it went out would be usefull.what yellow fuse ? go to the technicians corner and get the service manual and locate the part via the number on the board next to it and find it in the service manual so you know what it is.
hi thanks for the input the yellow fuse tested is right above the inline fuse on the g board power supply there is 2 small yellow pico fuses above that inline glass fuse thats it.The tv just wont power on or nothing.shut it off and it wont do anything.also couldnt find part number on pico yellow fuses on the g power supply board.The pico yellow fuse is open 3.15 amps so i dont know how to check from there.Can you help. Please im not a electronic specialist and i dont have alot of mony to have service come fix it.They want a arm and a leg just to come and look.I could use some friendly help if you can. thanks
http://www.techlore.com/article/14476/Troubleshooting-a-TV-For-a-Dead-Co...
The pico fuses are just like regular fuses just check for continuity or ohms.if you get any there usually good
