Hello, I have both a 62525 and 52525. I thought i could get one of them working but no dice. Can someone with experience PLEASE help me? I get a red lamp light. I have a brand new lamp. I am getting 420 VDC at the lamp ballast. Is this too much? I am not getting any volts out of the lamp ballast. I replaced the lamp ballast with the other one I had but it didn't work. That one may be broken also because both TVs have the same red lamp light. How can I make sure the lamp ballast is good and is 420 VDC too much from the power board. The capacitors on the power board look fine but I haven't tested the power board. The manual says check for 340 VDC at the lamp ballast.
Thanks in advance!
