Apparently the Mitsubishi WD TV's have a problem with erroneous readings coming back from the Thermal sensor that makes it tell you that the “TV will shut down in a few seconds. Please check if the air flow is blocked ”
Does anyone know how you can bypass the sensor and just eliminate it?
