WD-62525 ( Orange Status Light )
crawdad1979
Hi Larry - you've helped me before with the blinking green light problem, so I thought you could help me with this issue.  I received a new chassis from Mitsu they agreed to do this on all tv's that had the blinking green light problem.  I attempted to reinstall it last night and when I got finished I noticed that the status light was blinking orange.  Do you have any idea what may cause this?  I took the back panels off and went over every connection and I can't seem to find anything wrong.  thanks for your help.
CVinje
Don't know if this is the
Don't know if this is the cause of the problem, but in another thread Larry posted a reply to a user asking about the same problem and stated the following quote:
"generally when you get a orange yellowish/orange light there is an error with the lamp door cover meaning it is not screwed into the lamp cover correctly good luck
Larry Dillon"
Hope that helps, otherwise, wait for the more knowledgeable to help!
CVinje
