My TV has the timer/power light flashing a continuous fast green. When I hit the system reset button it begins the same flashing pattern. My dealer said I needed a new bulb and I installed it and it did not effect the flashing light. The bulb was the original from 1995. I have seen other questions on this in the blogs and they mentioned changing out some capacators. Can you give me insight on this problem?
Mitsubishi WD-52725
Fri, 06/25/2010 - 00:40
Mitsubishi WD-52725
