my sony KF-50SX300U tv wont turn on
the lights at the bottom flash in a repeated pattern of ...red, green, red, green... a short pause and then same sequence again
what could be the cause of this and would i be able to fix it myself?
i am assuming it isn't just the bulb as the bulb light (or what i think is the bulb light) isnt on
Hi,
First step is to replace the XL-2100 bulb or lamp. That is the most likely problem. Bulb failure is normal after a few years of use.
easyab
