mitsubishi ws-55511 "blinking green light" & "2-2" problem
jonyk
2 yrs ago i fixed a "2-2" code problem by replacing the IC convergence & 2 fuses.  last week my cable went out for a short while and, afterwards, when i went to turn the set back on, the power light came on for about 3 sec and then the set shut off.  i pulled the plug on the set for a while.  when i tried again to turn it on again, it was 3 sec and another shut down.  i left it unplugged overnight.  when i plugged it in the next morning, instead of the 3 sec shut off, i got the "blinking green light"  that wouldn't stop until the plug was pulled.  I replaced the capacitors in the DM module.  the "blinking green light" is now gone but i'm back to the original problem - the set is shutting done after the green light comes on for about 3 secs & i'm getting the "2-2" code.
i guess the next thing i will do is replace the IC convergence & the 2 related fuses that go bad with the IC failure and hope the set works.
i wondering if anyone has any insight as to why i might have both problems happening at the same time?  if there might be some reason why this has happened?  any thoughts would be greatly appreciated.
jonyk
replaced the capacitors on
replaced the capacitors on the DM module as described on other posts & the "blinking green light" issue went away.  the "2-2" code issue was resolved by replacing the IC convergence & PFA04 & PFA05 fuses as often described on posts.... i let a pro do the soldering for IC convergence chip & WS is back in operation now.
