Part One: How to rip DVD to iPod
Part Two: How to convert video/audio to iPod
Part Three: How to transfer iPod to iPod, iPod to PC/iTunes, PC to iPod
Part Four: How to create iPhone M4R ringtone from your own video/music
Make Preparations: Download iPod Mate.
First, click "DVD to iPod Converter" on the main interface to run DVD to iPod Converter.
Step 1. Open your DVD Drive and put your DVD in it, then click "Load DVD" and choose "Load DVD" to load your DVD into this program.
Step 2. Choose your output format from the "profile" drop-down list.
After you choose your output format, you can adjust your output video's settings, such as "Resolution", "Frame Rate", "Bitrate", "Sample Rate" and so on.
Step 3. Click "Start" now to begin your conversion and you will get your video soon.
First, click "iPod Video Converter" on the main interface to run iPod Video Converter
Step 1. Click "Add File" to load the video you want to convert.
Step 2. Choose output format by clicking "profile" and customize your own output video by clicking "settings" to adjust the Resolution, Frame Rate, Bitrate and so on.
Before you click "Start" to begin your conversion, you can do some editing works, such as pick up a part of your video to convert(trim), choose your own play region(crop) and put two or more files into one.(merge into one file).
Step 3. OK, now you can begin your conversion by clicking "Start" button.
First, Click "iPod Manager" to run iPod Transfer software
* Click "PC to iPod" button, it will allow you to transfer songs and videos from your computer to iPod easily.
* Click "iPod to PC" button, it will allow you to backup your songs and videos from iPod to your computer.
* Click "iPod to iPod" button, it will allow you to transfer songs and videos from one iPod to another iPod dirrectly.
First, Click "iPhone Ringtone Maker" to run iPhone Ringtone Maker software
Step 1: Click "Browse" on the right side of "Input File" to import the file that you want to make ringtone from it.
Step 2: Play it and listen the music to find the segment that you want to use it as ringtone. Then drag and click the start & end slider to set your wanted segment, or type the start & end time in the corresponding text box directly to get the exact segment. You also can pre-listen the converted audio before generate.
Step 3: Click "Browse" on the right side of "Local Output Folder" to choose the output destination.
Step 4: Check "Export to iPhone" option, the converted ringtone will be load to your iPhone directly.
Step 5: After all the settings are finished, click "Generate" to begin making your own iPhone ringtone.
Here I also recommend you some iPod softwares: DVD to iPod Converter, iPod Video Converter, Flash to iPod Converter, iPod to Computer Transfer, iPod to iPod Transfer, DVD to iPod Converter for Mac.
