Part One: What is TS, MTS, M2TS?
TS is the abbreviation of Transport stream (in high definition). It is a communication protocol for audio, video, and data which is specified in MPEG-2 Part 1, Systems (ISO/IEC standard 13818-1) (TS == Transport Steam).
Nowadays, TS files are widely spread on the internet as (usually split) recording profiles from HDTV broadcasts. Some Camcorders such as JVC Everio GZ-HD40 also support this HD format.
MTS format is a high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony Canon, Panasonic.
.MTS files are used premarily with Sony hardware. Camcorders make use of MTS in the form of AVCHD, a recording format made specifically for camcorders. Some camcorder models from Canon also use MTS files. These files are also present on Blu-ray disc compilations, therefore they are capable of storing quite a large amount of information and data tracks.
M2TS file format is given to video/audio files created by certain Sony Camcorder models. A .m2ts file is a Sony high definition video file type. M2ts files are raw AVCHD videos recorded using Sony's , such as the HDR-SR(xx) series models. Panasonic, Canon and other brands of AVCHD camcorders also record in m2ts format. Currently, m2ts files can be played using the Picture Motion Browser, which is an application video player provided with Sony AVCHD camcorders.
Part Two: AVI, WMV, MPEG-4, H.264, MOV, M4V, DivX, XviD, ASF, MPEG-1, MPEG-2, 3GP, 3GPP, MKV, FLV, SWF, VOB...
Tools Introduction:
Aiseesoft HD Video Converter is best HD Converter to convert HD TS, HD MTS, HD M2TS, HD MPEG, HD WMV, HD MPG, HD MP4, QuickTime HD MOV, HD H.264, HD RM video, etc.
Quick Guide:
Firstly, download the HD Video Converter, then install and run this program.
Step 1: Add Video
Click "Add File" to load the video that you want to convert.
Step 2: Choose Output Profile and Settings
From "Profile" drop-down list you can choose your output profile according to your need.
You can also click "setteing" adjust the settings of your output video, such as "video/audio encoder", "Video/audio Bitrate", "Channels", "Resolution" and so on..
Step 3: Video Editing
This powerful HD Video Converter allows you to do many video editings.
1. Click "Effect" to make special effect for your movie
You can adjust the "Brightness", "Contrast", "Saturation" and also you can use "deinterlacing" to improve you output effect.
2. Trim
"Trim" function allows you to pick up any part of your video to convert. You can just convert a part of your video that you want.
3. Crop
Cut off the black edges of the original movie video and watch in full screen on your iPod using the "Crop" function.
Step 4: Conversion
After you have done all the steps above you can click "Start" button to start your conversion.
Here I also recommend you some High Definition video converter: AVCHD Video Converter, TS Video Converter, MTS Converter, M2TS Video Converter.
