For both Mac and Windows users:
This article is aimed at showing you the easy way to enjoy DVD and Video on your portable devices.
The following content includes two parts:
Part 1: How to rip DVD and Convert video on Mac OS X with one tool-iSkysoft DVD Ripper Pack for Mac
Part 2: How to rip DVD with Tipard DVD Ripper(for Windows)
Part 3: How to converter Video with Tipard Video Converter(for Windows)
Part 1: How to rip DVD and Convert video on Mac OS X with iSkysoft DVD Ripper Pack for Mac
Make preparation: Download and install iSkysoft DVD Ripper Pack for Mac(Intel Version or Power PC Version)
Step 1:Select and run “DVD Ripper for Mac”, Click “Load DVD” button to load your DVD.
Or, click “Load IFO” button, browse your computer, find the DVD folder
of the movie you want to add from your hard disc or DVD-ROM, open your
DVD folder, open the VIDEO_TS folder, select all the IFO files and
click OK.
Step 2: Output setting
Set the output format you want from the “Profile” drop-down list.
Click “Settings” button to open the Settings window and set video
resolution, frame rate, bit rate, encoder, etc. iSkysoft DVD Ripper for
mac lets you extract audio from DVD movie to MP3 or AAC, etc.for web
using or other portable players. You can set audio resolution, frame
rate, bit rate and encoder on the “Settings” panel.
Step 3: Cilck “Convert” button to start your conversion
Waiting a short while, the conversion will be finished.
More editing functions
1.Trim
Click the “Trim” button to to trim the current title or chapter by
dragging the Start Time slider to set the start time, and dragging the
End Time slider to set the finish time. Then you can only rip segments
from dvd on mac.
2.Crop
If you want to remove the black edges or just convert an area from your
movie video, you can click “Crop” button to crop the video of the
current title or chapter. You can specify an area either by dragging
the frame around the video or setting the crop values: Top, Button,
Left and Right.
3.Capture pictures
With this program, you can preview the movie in the preview window on
the left of the main interface.While previewing the movie, you can
capture pictures by clicking “Snapshot” button. Click the Snapshot
Folder button to open the folder where the captured pictures are saved.
You can also specify the folder where to save the pictures. Choose a
format (JPEG and BMP) for the captured pictures to be saved as. Then
Click Ok to finish the settings. You can find the pictures in the the
folder you specified.
4.Effect
If you want to adjust the video effect of your movie, you can click
“Effect” button and drag each effect adjustment slider to set the video
brightness, contrast, saturation and video volume. You can also choose
a special effect from the Effect drop-down list to apply to your movie.
How to Convert video with iSkysoft DVD Ripper Pack for Mac
Step 1: Select and run "Video Converter for mac" and then click “Add File” button to add your video.
Step 2. Output format and Settings
From the “Profile” drop-down list you can find one format that meets your requirement.
To have your own video settings you can click “settings” button.
After doing the 2 steps above, you can click “Converter” button to start conversion.
If you want to edit the videos, the functons such as "Capture your favorite picture", "Crop video", "Video Effecting","Trim video","Merge videos into one file" are also available and very easy to use.
Make preparation: Download and install Tipard DVD Ripper
Step 1: Click "Load DVD" button to load your DVD.
This professional DVD Ripper can load three DVD source, you can load
your DVD from DVD drive, DVD folder in your PC and also IFO file.
Step 2:Select the output video format you want from the "Profile" drop-down list.
Step 3:Click the "Start" button to begin your conversion.
You can have a coffee or have a walk now ! In a short while the conversion will be finished.
Some powerful editing functions such as "Capture your favorite
picture, Merge videos into one file, Trim any clip of your video are
also available
Make preparation: Download and install Tipard Video Converter
Step 1.Click the "Add File" button to load video file.
Step 2. Video setting
Select the output video formats you want from the drop-down list of profile
Note:
By clicking the "Setting" button, you can set the video parameters and audio tract.
Step 3.Click the "Start" button to start conversion, it is very fast and in a short while your conversion will be finished.
Ok, now just have a try and get the wonderful experience!
