Samsung HCN4226W
4 posts / 0 new
Lane1223
Samsung HCN4226W
Ok I have been searching for answers on what might be causing the bowtie effect on the rear projector, I just replaced the IC's and still same issue, I checked the IC board for the resistors and they all seem to be fine. could it be the lenses? Also the screen whent bad out of no were, it was not dropped moved ect...
Is there something I am missing?
Alnp
Have you looked at the other
Have you looked at the other threads for your set? have the service manual from the downloads section?
there are also fuses that need to be checked
http://www.techlore.com/forum/thread/21399/Samsung-42in.-HCN4226W-Red-Co...
Samsung HCN4226W chassis P55A
some other models w/ P55A
HCN4226WX/XAA
HCN4226W3S/XAA
ST54T8PCS/XAX
HCN4727W5S/XAA
Lane1223
Yea I was doing more research
Yea I was doing more research last night and found that what I thought were resistors were fuses so I checked them and it seems that one of them are out same with 3 resistors so I am placing an order forthem and will post back on what the turn out is. Thanks for the reply.
Lane1223
Ok so I changed out the pico
Ok so I changed out the pico fuses and it worked so after 30 dollars I got it working 2 ic's and 2 pico fuses. The only thing wrong now is at the top and bottom about two inches of off color bar is brighter/ clear barely not too noticable but enough to see
