I have a mits wd62825g with the green blinking LOD. Can someone email a copy of the doc's to R/R caps (and any other docs needed to try and repair)?
Is it sometimes necessary to re-flow solder on the DM board? Seems to be times when changing caps doesn't fix the problem.
Also, the picture jumps at the bottom especially. Don't know if this is related or seperate issue with the light engine (correct term?). Guidance appreciated!
