Mitsubishi WS-73909 light turns ON Click.. turns OFF Click... TV will not turn on
Steivn
  I replaced the caps in March when I had the flashing green light of death =c) , worked great till this morening I turned off the tv by acct. whent to turn it right back on the green light came on hear it click ok then it turns rite back off didn't even have time for sound or picture just turned rite back off.I unpluged it plugged it back in waited the 70 sec till light stopped blinking same thing again click rite back off.
I checked the code it was (2 flashes pause it does this 10 times) I did a hard reset it gave me (1 flash pause the 2 flash pause 5 times) I then tryed to turn on tv same affect green light for a few secounds then turned rite back off. The code when back to 2 flash pause 10 times any ideas , I don't think this is a cap problem this time Please help
Steivn
Steivn
I have the 73909 if I hit the
I have the 73909 if I hit the reset button or unplug and wait till green light goes of (after about a min or so) check the code it's a 12 ( 1 flash pause 2 flash pause)then I go to turn on it clicks on then clicks rite back off then the code it 22 i guess ( 2 qick flashes then a pause), Larry said prob the convergence IC's are bad and it sounds like a short. He was kind enought to tell me where on the site the tech man. and oper. man. was but I don't know what they look like or where they are located in the set.
I read larrys other post to people with diffrent models say'n "In some cases the regulator IC, a shorted horizontal output transistor,and a shorted convergence IC can cause the set to be in a dead state." Just wondering if that could be my case or would it be just the convergence IC'S
I replaced the cap on dm in march and it took care of the flashing green light of death and it's been working great but this just happened last week where it would turn on. can anyone help ?
Thanks Steivn
