Hyundai 15 inch LCD tv power up problem
1 post / 0 new
opy
i have another project personal tv..its a hyundai 15 inch LCD tv
i
have had it for about 1 yr got it used  and has worked fine up until 2
months ago..i have yet to actually get a lcd tv working that was
broke..if anyone can please hekp my confidence and get this tv repaired
here is what happeened.....tv worked
fine but then when powered on the power light would flash yellow for a
while and make like static noise in and out quiet then loud...and would
not power on...i then would power it off and then power it back on and
bam it powers on with a pic....and would work fine.......well it got
worse and worse...sometimes would have to wait 15 min and come back and
then the pic was on.....but now its dead..will not power on no power
light nothing........i took apart and found 1 1000uf 16v cap tested
real high ESR so i changed it and still no power at all ...all of the
other caps seem to test withing range using my ESR.......any
ideas????....from what i descibed what part could have caused
this??....also i tested 2 large diodes and when i test them one way is
no reading and the other was comes up 200 using a DVM......when i test
any other diode on any other baord one way is zero and the other way is
like real high like 600-800.and even online they say it should read
high like 600  or more.....would the 200 reading mean they could be
bad???
i have pics of the board if anyones wants me to email them.......any help would be appreciated
but from what i have described i want to find out if anyone can maybe direct me to what could be the causing of the tv not to power on anymore
jim
