My Mitsubishi VS-60719 60-inch Rear Projection Set Won't Turn On?
Buzz55
I have an older model Mitsubishi Rear Projection TV - Model # VS-60719.  The TV will no longer turn on, only a solid green light will appear for about 10 seconds, then shuts off.  Appears to be a common problem!  No picture on the screen appears, and no sound.  I also hear a faint clicking sound while the green light is temporarily on?  This also does not appear to be the "blinking green light problem" I have read about on other posts, the green light on my set is a solid green light.  While the light was lit, I pushed the menu and input buttons simultaneously and received a 2:1 blink code?  Before the TV went into a coma, the S-Video inputs and the RBG Component Video input (for a DVD Player) didn't work properly?  I would get audio on these inputs just fine, but a purplish scrambled video signal...not sure if this is related or not?  The DVD player was last hooked up to the old yellow video input and worked just fine.  Any suggestions would be greatly appreciated.  Buzz   email: [email protected]
Buzz55
Larry, can you please comment
Larry, can you please comment?  Apoligies for asking you to repeat for the 100th time.  But most of what I have read relates to the "blinking" green light, I have a "solid" green light problem which probably is a different solution?
