WD 52526
ispca
WD 52526
WD 52526
My Mitsubishi WD 52526 - LIGHT IS BLINKING.
I replaced the bulb, it was not working  100%. I replaced the house with a new bulb, it  is not working. The gree light is blinking.
Any suggestion?
Walfredo de Freitas
jmora
Hi Walfredo
Hi Walfredo
When you turn on your tv do you hear any particular sounds like a buzzing, humming or rapid clicking noises? if you do it's most likely an issue with the ballast on your tv, also another question is when you turn on your tv do you hear the fans running? if you don't that also could be an issue with the fans not working automatically shuts down your tv, it's highly recommended for you to check this or also to check for this with a service technician, I recommend this website: www.nesda.com, this website holds the largest listing of registered service man in the continental usa.
Good Luck
ispca
jmora said: Hi Walfredo When
jmora said: Hi Walfredo When you turn on your tv do you hear any particular sounds like a buzzing, humming or rapid clicking noises? if you do it's most likely an issue with the ballast on your tv, also another question is when you turn on your tv do you hear the fans running? if you don't that also could be an issue with the fans not working automatically shuts down your tv, it's highly recommended for you to check this or also to check for this with a service technician, I recommend this website: www.nesda.com, this website holds the largest listing of registered service man in the continental usa. Good Luck
Hi there,
Funs  running, but after few seconds they stop. There are not any sound as buzzing, humming or rapid clicking noises.
