RCA D52W20 ITC222 used to flicker, now dead
Cmason
TV flickered when turned on lately and took a
little bit before the picture would stay put. Flickered up and down
color ok 10-20 secs. Now it turns on and off 3 times.
It has been sitting a week or so and I thought I
would try the service menu. It came up, still flickered a bit before
being normal. I went through all the options but didn't understand them
all. After a couple minutes the tv color started looking a bit...
yellow? darker? It went back to normal once and then back, just like
flipping a switch. It isn't hooked up so I won't be watching it until I
figure it out.
Error Codes Count Timestamp
33 004 020307:24
34 125 same
31 055 same
51 047 same
44 009 same
Any help would be great.
cuda
check capacitors cp150,cp120
check capacitors cp150,cp120,cp114 for buldgeing tops and change them out if so,these are known to cause this problem. They are on the sweep/power supply board.
Cmason
Nothing is buldging and the
Nothing is buldging and the backs of all the boards in the back appear to be ok. Also can not see any cracks in the lamps up front but they are mostly covered.
