JVC-GMV42UG plasma monitor repair question
capz
Hi all. This plasma was given to me. I'd like to try and fix it myself. The tv powers on. The best I can describe the symptoms is the screen looks fuzzy and the colors are all psychedelic. I opened it up and the only thing I noticed was two (out of 4) bulging high voltage capacitors on the power supply board. They're the large 1'' 450V kind. Could this cause my problems above? If so I'll try and replace them. Any particular brand cap I should get so this doesn't happen again. Thanks for any insight.
dach shock
Those caps are quite likely
Those caps are quite likely the problem. Use a hi quality replacement, not generic. MCM Electronics supplies a line of hi temp/hi frequency caps that I use. Also check wikipedia
